Re: Bob M, I need your help
Posted by Janicholson on July 21, 2007 at 19:20:40 from (66.173.50.147):
In Reply to: Re: Bob M, I need your help posted by Paul Shuler on July 21, 2007 at 18:55:28:
Because it does nothing, And the starter is not connected to anything but the battery and the big switch, here is the diagnosis procedure: A cheap volt meter is needed Digital is OK but a meter with a needle is better. With the tractor in Neutral, and brakes locked, put the meter on volts and set to the next higher volts than the battery. Ground the positive lead and touch the other to the starter terminal at the starter. Push the big button, if there is voltage there, the starter is open. Take a plastic faced mallet, or block of wood and a regular hammer and whack the starter at the end not bolted on. Do not hit to maim, hit to jar it. Then try the Switch again. If nothing, the starter is bad and needs to be rebuilt. Brushes springs, drive, and bushings. If it turns now it needs the above because the fact that it turns means that the brushes are bad and you just gave them one last attempt at starting. I there is no volts, the cable or switch is bad, or the ground cable is bad. Test all connections back to the battery for volts Switch on when it is in the circuit. It is that simple. If it has a mag, do the take the wire off thing and then try it. JimN
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
