Re: wheels and water pump Super A
Posted by ScottyHOMEy on July 23, 2007 at 06:09:15 from (70.105.246.111):
In Reply to: wheels and water pump Super A posted by R. Baker on July 22, 2007 at 15:36:01:
On the Super C, the sensor is mounted on the right side of the radiator inlet at the top, the part that is also the fan mounting bracket. Not sure what the fitting is, but it looks to be a 1/8" or 1/4' pipe thread, and is tapped into inlet, on the flat below the upper bolt. Being on the right side, you can route the cable through clips bolted into the holes you'll find at the front and rear of the engine block, just above the rod from your throttle lever to the governor, and below the plugs. In my experience, you'd do best to get the inlet off the tractor to drill and tap it for whatever thread the sensor comes with, rather than try to do it on the tractor. And in my furher experience, if you're not set up to make sure you drill and tap straight and clean, you might consider having a machine shop do it for you. It can be might hard to get a thread started in cast if you don't have the right tap for it.(That was an expensive lesson; I'll spare you the gory details!)
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
