Re: Farmall B coil
Posted by Janicholson on July 27, 2007 at 20:48:28 from (71.87.39.51):
In Reply to: Re: Farmall B coil posted by Dave H (MI) on July 27, 2007 at 18:26:55:
Simple test. On the side of the distributor, there is a connection that goes to the coil. Loosen the nut and remove the wire. Turn on the house wire switch and check the end of that wire for volts. It should be battery volts, or minus a couple from battery volts. If so, it is probably an OK coil,(but not for sure)If there is no voltage at the wire in this experiment, and there is on the switch side of it, the coil is toast If yes, take the distributor cap off and look at the points. If they are closed (together) turn on the switch again and touch the disconnected wire to that terminal you took it off of. A small,but clear spark should happen where it is touched when it is touched and removed. The wire from the center of the distributor if held with insulated handled pliers, or a dry stick, next to the block, about 1/4" away, will also spark a hot blue spark. If this does not happen, the problem could be in the points, or condenser. Put the wire back on the distributor. With a small plastic handled screwdriver, and the switch on, reach in and open the points carefully. getting the screwdriver touching ground will not hurt anything, so do not be nervous. If this causes spark, the problem is probably that the points need to be cleaned. A fine emery board, followed by a piece of a folded dollar bill will make them clean enough to work. They should be set at .020" when the little breaker cam is opening them on a high point. Hand turning the engine is best for this, with the switch off. Try these items then get back to us. JimN
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
