Re: Farmall C Timing Gear Question
Posted by ScottyHOMEy on July 29, 2007 at 16:32:13 from (70.105.246.111):
In Reply to: Farmall C Timing Gear Question posted by Justin S. - TX on July 29, 2007 at 16:07:39:
I'm not sure what you're looking at. If you see a gear through the timing cover, it's the cam gear. A gear at the front of the crank drives the cam, to the upper left aa you look from the front. Continuing to the upper left, the cam gear then drives the gear that turns both the governor and distributor. I'm thinking you may have got into trouble with your work on the governor. Try pulling your governor and distributor back off. Pull off the flyweights and bearings, etc. on the governor side, then pull the gear out. Bring the engine around to TDC on #1 compression. You might have to move it a little bit by hand to get it to line up so you can see it, but there should be a punch mark visible on the cam gear (there's actually two of them. If you can see them both, great, but the timing cover may allow you to see only one). You should see two corresponding punch marks on the governor/distributor drive gear. Put that gear back in so that the marks line up with the mark(s) on the cam gear. Put your governor back together. With the rotor lined up to point to #1 on your distributor, put the distributor back on. Hook it all back up and reset your timing.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
