Re: 460D needs rebuild, I need help.
Posted by Owen Aaland on August 05, 2007 at 20:52:55 from (65.165.246.212):
In Reply to: 460D needs rebuild, I need help. posted by Help needed on August 05, 2007 at 19:54:07:
To get a 460D to start decent you need to have all the glow plugs working. You can check them without taking them out. Disconnect all but one and then press the glow plug switch. A good plug should move the meter about 1/3 to 1/2 way. Check them all one at a time. Replace any that do not move the needle in the gauge. With the glow plugs warm, 30 to 45 seconds in warm weather, try to start the engine. If you get steady white smoke out the exhaust while cranking, the injection pump and injectors are working. Slow cranking speed will cause a hard start situation. If when you have the glow plugs working and you are sure that you are getting fuel to the cylinders, it does not start on the starter but does readily start by pulling, repair the starter, battery, and or cables. 460Ds are very sensitive to proper valve recession in the cylinder head. The original specs were from .003 to .046 below the surface of the head. Later specs called for .048 to .064 or in that range. Use the early specs and keep them as close to .003 as possible. Once you get near .050 it will be hard to start. How much blowby do you have coming out the breather pipe on the side of the engine when it is pulling hard? That will give you a good indication to the condition if the sleeves and pistons. Too much blowby or a properly maintained breather system can be the cause of a lot of oil being blown out the breather pipe. It is not unusual for these engines to blow more oil out when lightly loaded than they do when they are pulling hard.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
