Georgeky and Hugh MacKay..........Iiiiiiii did it! :)
Posted by Patrick Martin on August 08, 2007 at 20:29:59 from (64.154.26.250):
Fixed the little pump and finished my 3 point hitch!
You know what....the solvent did indeed eat up the old felt/rubber seal. It was hard as heck to get the old retainers out but I managed after much toil. It was just as bad as doing the PTO output seal too. I had to like drill and use a slide hammer to beat that one out.
The shaft wasn't worn at all and the seal fit tight BUT I could see where it was starting to show some friction so I know I wasn't too far from it. I had to use a pick to work the lip of the seal around that stepped shoulder on the shaft but after that ploooop she went right on.
Anyhoos....here are some pics. Now I did take some pics of the innards but the resolution was so bad I couldn't get them to show any detail.
I split the pump and pulled the impellers, brass bearings, gear, and spring then cleaned and replaced them all and put fresh O-rings in. It still looked new in there but I figured what the heck.
third party image
third party image
third party image
third party image
third party image
third party image
third party image
third party image
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
