Re: F-14 Clutch
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill B on February 12, 2000 at 20:47:55 from (209.182.66.21):
In Reply to: F-14 Clutch posted by RED Blooded on February 12, 2000 at 18:30:19:
Same thing happened to me with one of my F20s. Perhaps mine was worse, since it took the brake to stop it after the clutch was depressed. Once it broke loose, it was fine until engaged again. I took the clutch apart, and found that the engine had leaked some oil onto the flywheel, and the oil was sticking the clutch disk to the flywheel like a suction cup. I cleaned the flywheel and disk with brakekleen, and put it back together, and all is well. It's possible that is the trouble with yours.
There is another cause of shifting problems with the F12 and F14, and that is the belt pulley. There is no control for the pulley, so it runs when the clutch is out. When you push in the clutch, the pulley acts like a flywheel and continues to turn for a while, some times quite a while. You can't shift until it stops. That is why most F12 and 14s have the pulley missing. They shift much better with no pulley on. I have several F12s and a few 14s and not one pulley.
Post A Followup
: Re: Re: F-14 Clutch
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
