Re: 706 LP ELECTRICAL PROBLEMS
Posted by Owen Aaland on August 10, 2007 at 00:40:55 from (65.165.246.212):
In Reply to: Re: 706 LP ELECTRICAL PROBLEMS posted by John T on August 09, 2007 at 05:15:16:
The ignition resistor on the 706 is in the wiring harness between the switch and the solenoid. If the wiring harness has been replaced or repaired it is quite possible that this wire has been replaced with a regular copper wire. If that is the case you will need to add a resistor to the circut. Check the voltage at the battery side of the coil with the engine running. It should be about 6 to 7 volts. If you do not have a resistor in the circut you will see 12.5 to 14.5 volts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
