Posted by Wardner on August 12, 2007 at 13:02:32 from (4.154.244.29):
In Reply to: I-4 Hitch posted by Harold H on August 10, 2007 at 08:35:37:
Harold,
I went to a tractor show today and looked at a OS-4. The U-shaped brackets under the axle housings are smaller in a couple of regards. The vertical bolt holes into the axle housing are smaller and the center to center distance is one inch shorter. The cross bolt (hinge) is smaller as well. The inside dimension where the welded pipe sections go is the same.
I suggest that you use your brackets and bush my lower struts down to 5/8th or 3/4". I didn't measure that bolt size.
Because the bracket and the bracket end of the strut is downsized, I am assuming that the I-4 struts for the pintle is also a smaller section. Probably 5/8ths or 3/4" x 2". If you are looking for complete authenticity, you will have to fabricate new struts. Not a difficult job and well within the capability of any welding shop. It is something I could do as well. The length of the struts can be calculated using the Pythagorean Theorem.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
