Re: Charlyn PS shaft removal.
Posted by glennster on August 13, 2007 at 06:24:20 from (76.224.20.243):
In Reply to: Charlyn PS shaft removal. posted by dej(Jed) on August 13, 2007 at 05:30:45:
the end bearing has balls all the way around, then on the other side of the shaft you will see a seal in the bolster, there should be a bushing driven in there the shaft rides on. carter and gruenwald has a rebuild kit for the front bolster, comes with all the bushings, bearings and seals. when you drive th roll pin out, support the shaft with a block of wood, there is a retaining clip in the coupler, that thing is a evil to get back in if you knock it out. when you get the pin out of the coupler, the shaft will unscrew out the front of the bolster. if you are dropping the main steering post shaft, what i do is jack the front end up so the wheels are just off the ground, hook a 2 jaw puller on the bolster housing, then snug it down on the shaft after loosening the nut that holds the top sector gear on. then whack the bolt on the gear puller a little, the top gear will pop loose, leave the nut on until you get the front wheels off, then put a floor jack under the shaft, remove the nut and ease the shaft down. that shaft is pretty heavy too!!
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
