CHAD S I NEED HELP
Posted by noidea on August 13, 2007 at 19:19:57 from (71.79.45.224):
I took my carb apart and found out that the top half is from a 715. The bottom is from an M. I drilled the main jet out to 7/64ths=.109 I also took the metering stem out and made the bottom set of holes the same size as the top holes. It has a #35 venturi. I used the M load screw and packing. This went well. I could flood it out now by backing out the screw. Well I decided to hook up my multispark box from Summit racing. When I hooked it up and when I crank the engine over it only fires some and it won't hardly start. When it starts it sounds like it is running on 1 or 2 cylinders and it only goes for about 10 seconds. I checked the box and it is sending spark just fine. It is set to six cylinder mode. All of the wires are hooked up per the instructions and I took out the condensor. What is the problem? Could it be my plugs or plug wires?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
