multispark problem
Posted by noidea on August 14, 2007 at 18:24:03 from (71.79.45.224):
What is wrong with my Summit Racing multispark ignition box. All of the wires are hooked up correct according to instructions. It would run on what seemed like two cylinders for about ten seconds. Now it won't start period. The light flashes when you turn the key to indicate that the unit is functioning properly. When I crank the engine the light doesn't flash as it should. This according to the instructions means that my pickup method isn't working. The white wire is connected directly to the post coming out of the distributor. What is wrong with it?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
