Often if a battery is like totally dead but not internally shorted n it has sufficient electrolyte, it can take a good while before she ever starts taking amps so leave it on high charge a while n see if she ever starts drawing current. Sure you can jump it buttttttttttt a totall dead battery may be like an amp suckin drain so you might (if it has a good charging system) be able to jump the STARTER ONLY n if she starts a good genny can supply the meager 4 amps required to power up the ignition.
Id take that battery to a shop for a good test n let them try n re charge it n load test it. If your charger is only a wimply lil trickle charge Im not sure if it will ever come to life. I set mine on a high charge rate n let them set n cook a while n finally once they (if ever) take amps i back it of for a good slow deep charge.
See if theres electrolyte above all the battery plates and that no cells have a different or gray milky color??? Give her more time on a charger,,,,,,,,,try n jump start (AT CORRECT POLARITY) ,,,,,,,,,,and/or try to just jump the starter n see if she will run????? Will it pull start?? (requires a good genny like Jim mentioned)
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
