Re: Generator Adjustment
Posted by John T on August 15, 2007 at 16:16:13 from (66.244.83.147):
In Reply to: Generator Adjustment posted by jeffalex2 on August 15, 2007 at 12:29:37:
If it is the older 3 brush genny the closer the adjustable brush is to the fixed brush next to it the more she charges. As far as Voltage Regulator air gaps n spring tension adjustments, Im not into that over the net as it can be pretty delicate. Regardless what genny or system you have, if you dead ground the gennys field post thats the MAX charge (still subject to any third brush setting) so if it still dont charge to suit you it may need some genny repair. Make sure the belt is tight and the genny and VR are both well grounded.
John T
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
