Posted by Chipper on August 15, 2007 at 19:55:11 from (207.68.239.252):
Bought a 450 this week and had the bowl off the carb today. Engine is fresh but tractor had pretty much been sitting up for the last 2 years other than the occasional crank and stroll around the lot. It didn't want to seem to open up as much as I thought it should when I got it. It than began to run ruff and flood and then clear up. It would then hang up and stay at one particular rpm reading regardless of where the throttle was. I pulled the bowl off today and everything internally looked pretty clean except the needle would stick just a little in the seat. A light tap would free it. I went ahead and put a new needle and seat in and cleaned the screen on the fuel supply line which was almost stopped up. I put it back together and cranked it but still isn't running right. What's the standard setting on the idle mixture, throttle stop and fuel setting screw? I've also got to check to see if the governor is gummed up anywhere.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
