Posted by MN Scott on August 16, 2007 at 06:51:29 from (206.9.216.40):
In Reply to: Re: Gear Oil Leak posted by JJ in MI on August 15, 2007 at 19:59:28:
If you mean the transmission top cover no it does not need to be removed to replace the pto and axle seals. The pto seal is replaced by unbolting the retainer and sliding it off the pto shaft. Drive out the old seal and press in the new one and bolt the retainer back on. The axle seals require you to remove the wheels, do this one wheel at a time. Wire brush the axle shaft clean from rust and paint. Unbolt the retainer, slide it off the axle and drive out the old seal and install the new and slide it over the axle and replace the wheel. The brake pinion seals, brake shaft seals and the front two seals can also be changed in a simaler manner. If you don't have a repair manual get one. It privides tne information needed to replace the seals correctally. This website sells them. Good luck!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
