Posted by chadd on August 16, 2007 at 09:07:53 from (65.54.155.14):
Well, I replaced the cap, points, and rotor, and it runs better. However, it still has a definite miss. It occurs at the exact same time each time it occurs, and is not random. It appears to occur every cycle. It results in a sound like the engine is galloping. It is also accompanied by a small puff of smoke. I tried Janicholson's advice and switched 1 and 4 plug wires. The engine ran without stalling, but it was backfiring through the carb and had no power. When I switched 2 and 3 it would only fire three or four revolutions and then stall. With 1 and 4 and 2 and 3 reversed, it would not start. I am guessing the problem must be with cylinders 1 and 4 because when the two cylinders' sparks were reversed, it had less effect on the running of the engine than when 2 and 3 were reversed. Maybe a shorted plug? It's odd though, because it looks as though they are all firing. None appear wet.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
