bush hog, but I use an SMTA to pull it...
Posted by JMOR on August 17, 2007 at 17:59:26 from (76.185.68.29):
8 foot Austin MFG. It has never cut worth anything since I got it (used). Sharpened several times, compared the RPM, gear box ratio to another that I have (single 5 ft) and when blade diameter is taken into account, both are 10,000 feet per minute tip speed (about same as found in eqmt catalogs). One cuts good, one poorly. The poor 8 foot has two rotating systems and now that I have checked and compared most things, I'm wondering that if it's earlier life, someone had it apart, swapped the gear boxes or something that would maybe cause the blades to rotate in opposite directions (yes the sharp edge hits the weeds first),but that is just flipping the blades over.)
As it stands now, the left rotates ccw & the right cw such that in the middle, it slings cuttings forward and on the outsides, it slings toward the rear. Anyone out there have a two head cutter and know directions of rotation or any other idea why this one cuts so much worse than the other? Should blade plane be level? The good one has a slight downward rake at the front, about 1 inch lower than the rear.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
