Posted by Mike CA on August 18, 2007 at 22:16:34 from (64.173.170.7):
Good news: '44 H now lives in Suburbia. It is sitting in my driveway now.
Bad news: You are about to be flooded with a stream of questions! So be prepared. Ok, let me tell you about my day... but first, a pic...
Ok, so got up early and drove about 130 miles with the guy from the EDGE&TA club I joined in his rig and trailer. Winched the tractor on board and secured and picked up the parts he had to go with it... a new throttle since the current one has a stopper welded onto it, NOS gas tank, draw bar, old govenor and an original owners manual. We drove it home and off-loaded it from the trailer and got help from a neighbor to push it up into my driveway.
Later I washed it with my sons. Got a lot of dirt off of it, but there is still a good bit of caked on grime to work at. Later in the evening a question occured to me... I knew the owner had drained the water to save it from the big freeze in the winter. But was there oil? I learned that the oil pan had been smashed, and Tom (the EDGE member) suggested I take a good look in there to make sure the oil pump wasn't damaged. The damage to the pan could explain why I couldn't get the petcocks open. My ignorance on how to properly open a petcock could explain it as well. So, owners manual be damned, I set off to fetch tools. I grabbed a coffee can to open the drain plug a little to see if there was water in the oil, and if there was any oil at all. So I turned and turned and got a couple of drops, but no real flow, which I needed to see water, so I unscrewed it some more and... *pop* it flew right out of my hand against a thick stream of black oil! "Coffe can!!" I grabbed it and held it with oil covered hands... "oh crap, this is a lot... PLUG!!!" I grabbed it and wrestled it in an inch from the top of the can. I have oil all over my driveway now.
Day 1, lesson 1.... CHECK
Well, since I started it... I grabbed a bigger container and finished off the drain. Then I pulled the pan. Pump like fine as far as I can tell. Nothing bent.
So I spent the rest of the evening spreading kitty litter over the oil and I'm going to be sweeping in the morning and using a concrete cleaner after the tractor gets out of the way.
I've got a few questions about things I've found on the tractor so far. So be prepared...
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
