The M transmission contains only straight cut spur gears and single straight cut bevel set (differential drive gears). Consequently a GL1 rated lubricant is entirely adequate.
GL2 is OK too - it's essentially GL1 with some added rust/oxidation inhibitor.
GL3 and higher rated oils contain EP (extreme pressure) additives. These are intended for highly-loaded hypoid and spiral bevel gearing. These additives are unnecessary and may be actually harmful to the "stone age" transmission in an old tractor. (Some EP additives cause INCREASED friction and wear in low tooth pressure-loaded spur gearing such as is in your M)
Bottom line: Buy the cheap GL1. It's a far better lubricant than the best that was available back when your M gearing was designed!!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
