well...it shows your valves are open! the ATF is running back down and out through the intake...no biggie, just keep adding...watch and see if it runs out when you pour in a certain cylinder...if it runs out immediately....that piston is at TDC or close and the intake valve is open...move to the next one and add more...it shouldn't run out so soon. Nothing is wrong so to speak..just where the pistons are sitting in the cylinders. old says it 'takes what it takes' for the ATF to work.
Once upon a time, I had a JD 430 that was stuck and stuck hard. I finally pulled the head and took a wood block and put it on top of the piston and whacked it with a sledge hammer until it broke loose. I tried everything else I knew and felt I had nothing to lose....it either had to move or come out...in pieces if need be. But, all was well..it broke free. I honed the cylinders a bit, put everything back together and it ran fine. Your mileage may vary.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
