Re: Janicholson: Question about sanding combine engine bore
Posted by Janicholson on August 25, 2007 at 05:35:08 from (66.173.50.177):
In Reply to: Janicholson: Question about sanding combine engine bore posted by chadd on August 24, 2007 at 22:43:57:
Dear Chadd,
The best is to just take down the rust spots, leaving the remainder as little affected as possible. The 45degree answer is correct, but it will make little difference as long as it is that, or less from up and down. You will not be able to make them disappear because iron expands when rusted, and it expands out of a little pit it is making in the original. When you can't feel them, they are perfect. If over sanded, two things go wrong. The first is that that you spend too much time, the second is thet there is a chance of removing metal around the pit and causing poor sealing there. This is just a touchup to flat. 400 is OK, Good luck with the project. Remember this as the engine performs for you. Many engines with 1000 times the rust are started by brute force and survive. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
