Parts list
Posted by Mike CA on August 25, 2007 at 11:20:32 from (70.136.39.100):
Henry asked me to post this. If you have an old parts H, or just some of these parts laying around, please contact me. Thanks!
Parts I need to get the tractor running:
Oil pan with 4 bolts and split washers
2 way Sediment bowl (for duel fuel)
Hydraulic control arm
Hydraulic control mount
New Steering wheel
Choke rod
Seat pan bolt (hinges where pan flips)
Wing nut for carb
Engine block water drain plug
Parts I would like to get the tractor up to show quality.
These parts I need to get in order to use my H for a night hay ride at my son's school. So they are important to me.
Light bar
Lights
Rear light
Rear light mount
Amp box
Starter switch and mount
Battery box
Battery box support
Original radiator cap with single arm
Throttle arm linkage
Hydraulic pump rear access cover
(4) original side bolts for the grill
Small gas tank and associate fuel line
Lower radiator hose
Glass jar pre-cleaner
Air cleaner pipe
Narrow front with non-adjustable wheels
Grill insert
Junked Grill (to fix my ripped away piece)
Manifold Heat Shield and attaching hardware.
Mag On/off switch
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
