I had trouble finding the 5/16'' fittings when I needed them, too. What I found was that most auto parts stores had a spot for them in a bin or tray, but that it had been empty for some time and it was ''too much trouble to re-order them because nobody needs those any more, those were for OLD CARS.'' Special order only.
I finally found an Auto-Zone where the manager took great pride in staying caught up on her inventory, and SHE had them in stock. I could have hugged her (tall good-looking blonde, too).
As for your replacement line not fitting, I had a similar problem with a Tisco fuel line. It simply isn't formed correctly. You can easily see the mistakes they made if you compare it to the drawing in the parts book. If yours is a Tisco line from the same production run, this is likely your problem, also.
I needed to get the tractor running again (you have to run them to keep them running), and finally went with a neoprene line that was SPECIFICALLY DESIGNED for fuel delivery. I routed it very carefully to keep it away from the exhaust manifold.
But that's a short-term solution. The long term one is to buy and bend some steel line myself. I've done a little metal working before: but unfortunately it was mostly metal buildings and radio chassis and cabinets, not brake or air lines.
As a result I have ruined several lenghts of line but have yet to produce a fuel line that fits right and looks good. When I finally do, the neoprene one comes off.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
