Posted by Doc Larry on September 04, 2007 at 05:33:53 from (216.146.101.227):
In Reply to: MD injector pump posted by Doug N on September 03, 2007 at 11:29:50:
Doug,
The transfer or lift pump supplies fuel at low presssure to a master plunger that delivers fuel at much higher pressure to the injectors. What you're describing sounds much more like a problem on the high pressure side, or possibly a timing issue as you mentioned. You definitely should get some smoke under load. I think the timing procedure is given in the owner's manual if you have one. If not, a fairly detailed explanation is on either this site or the Red Power site if you do a search of the archives. Sorry I can't remember which.
Assuming you've done all the filters and checked out the scavenging valve, you may end up having to get the pump checked out. I got lucky and found a good used one, cheap, after buying two that were worn out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
