Start with the out-put lever on the bottom of the steering sector to see if its tight on the shaft. mite have to take the steering sector apart and there could be loose key on the shaft or top bearing is shot. I have rebuilt several with new bushing,seals and bearing in the top of the sector. If the steering shaft with the steering wheel moves back and forth that bearing on the end is shot. You can remove the whole shaft by taking off the big nut on the end of the sector. It will screw out the end and you can check that bearing. You can call 319-430-3907 i am in the central time zone and live in east central IOWA GLAD TO HELP ANYTIME.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
