Posted by Lee in Iowa on September 07, 2007 at 23:20:58 from (66.172.198.23):
In Reply to: More 856 questions posted by Hayfarmer on September 06, 2007 at 21:18:06:
As Larry said you usually need a special clamp to get the second wedge loose. Unless you get lucky and the outside wedge comes loose first and you can screw the bolt out of the inside wedge. Then you can use a big punch and a big hammer (old axle and maul) to knock the inside wedge loose, just be careful no to damage the threads. But if the inside wedge comes loose first you need the special clamp. Have seen quite a few 856"s with add on turbos that ran a long time with no problems. Horsepower would depend on what turbo it is and where the fuel is set, but factory HP is around 100. Lee
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
