Probably the front seal. We have had alot of seals leak on the 400 series engines. The seal can be changed without removing the complete front end. Have to remnove fan and shroud. Remove A.C. compressor if equiped. If early tractor the front damper uses three hole puller late ones two hole. I use a hook type seal puller to remove seal. Put in new seal and wear ring on damper pulley. You will have to use two different lenghts of bolt to pull the damper back on the crankshaft using the retaining washer. Just make sure the crankshaft key is all the way in the groove and the pulley is lined up. Have any problems contact me
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
