Posted by Janicholson on September 08, 2007 at 16:55:40 from (66.173.50.4):
In Reply to: Farmall WD-6 posted by karsky on September 08, 2007 at 16:47:24:
Several things can make that happen: The ground switch on the manifold that shuts off the mag when in D mode could be disconnected, or broken, or not being moved. The linkages that operate the starting valve might be jambed (If it will not crank fast or at all suspect this) The plugs may be fowled and not sparking. Have you choked the devil out of it to get it to fire? some take extreme choke and rich fuel to run on gas. Is the mag in time? Will it fire on ether in the gas mode (do not try this on the D mode!!) is there a steady stream of fuel to the carb? Good luck, Keep us aware of the progress. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
