Posted by homard on September 13, 2007 at 07:03:25 from (214.3.92.170):
In Reply to: 230 snow plow posted by Schlijas on September 12, 2007 at 12:19:56:
Before you buy a blade, check to see what kind of hydraulics you have on the 230. A lot of blades are designed for "Touch Control" hydraulics (look for the rocker arms below the gas tank).
"Touch Control" is the same type of hydraulics found on the Super C. The 230 could have either "Touch Control" OR "Hydra Touch" hydraulics (or nothing). If it has "Hydra Touch" there will be NO rocker arms under the gas tank and maybe a set of auxiliary hydraulic service taps on the left side under the gas tank (note not all 230's with "Hydra Touch" have the aux. svc's.)
Knowing what type of hydraulic system you have will determine how you will mount and control the blade positioning
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
