Re: 350 Hi Utility
Posted by Unreserved dick on September 13, 2007 at 16:44:26 from (4.228.126.150):
In Reply to: 350 Hi Utility posted by Pat in Wisconsin on September 13, 2007 at 10:51:45:
Pat:
Brakes are straightforward, you should be safe just going at them without any manual.
Hydraulic filter is located inside the reservoir, under the seat. You have to pick the reservoir cover STRAIGHT up to get at it or you'll wreck the filter. The cover is heavy, so your best bet is to have some good strong help and a plan for setting the cover down somewhere (on a couple of 4x4s works) if you decide to go after the filter. Replacement fluid is Hytran, available at your IH dealer (5 gal. should do the entire system including the loader). Drain for the hydraulic reservoir is a plug under the hitch cylinder bracket. If you have factory power steering, I think that's where the return line from the steering column taps into the reservoir.
If it was me, I'd go ahead and paint the tractor.
Good luck. Sounds as though you got a great buy.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
