First, I have only tried this on a 123 engine in a 100, the cam gear can B removed. Drill and tap the gear for a puller, a harmonic balancer type will work. After its off drill and tap the center of the cam, install a stud and use washers to pull the gear back on. I usualy tap 7/16 course threads. all the drilling and tap'n is rite EZ on the cam and gear. I have done right many on sideways mounted engines in cars 2.5 GM's no problem. I still have the gear off the 123, it came off right EZ and the new'n went back on EZ'er than you would think. NO I would not remove the cam less I were going to do a rebuild.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
