Posted by Haas on September 14, 2007 at 13:54:39 from (12.65.78.83):
In Reply to: Belt pully seals posted by jjamna on September 13, 2007 at 19:36:48:
You may need to use a shop press and bearing separator to remove the gear and bearings from the pulley shaft. You may be able to drive them off, but I took the assembly to a shop and had them pressed off and back on. There is not a gasket on the flange that mounts the assembly to the housing. There are shims there to set the gear lash. Be sure you put the shims back like they came out and clean them and the mounting surfaces. Make sure they are absolutely clean when you reassemble but even then, you may have some seepage of gear oil due to there being no gasket, only metal shims. When it's back together, put a pint of gear oil in the fill hole on the belt pulley housing. The transmission lubes the belt pulley bearings, but it takes a while for the oil to sling up there, so you need to add some for initial lube. Oil circulates from the transmission to the belt pulley housing and overflows back to the transmission.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
