Re: Farmall B - carb...before I get too far into this
Posted by Janicholson on September 14, 2007 at 14:05:11 from (199.17.6.122):
In Reply to: Farmall B - carb...before I get too far into this posted by Dave H (MI) on September 14, 2007 at 12:49:23:
I can tell it looks correct. The actual install is correct only if the needle is not pushed to one side in the seat . The clip has only the task of pulling straight down on the needle (with no side to side influence) th assure it is comming down off of the seat when the level is low. There is as much as 1/16" slack in the distance between the needle head and the float tab when the float begins to pull on it (when upside down) There are so many different designs of these clips, and float tabs that it is hard to describe. Many work for "ever" with no little clip at all. Freedom is the answer to how best it works. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
