The noise is comeing from the planetary gears in the pto unit. Some noise is normal with wear. Be sure to check the oil level in the pto unit. It filled seperate from the rear end. Has a check plug on the left side of the pto houseing. If you have a fast hitch will have to remove top cyl pin & swing the cyl back to get to the plug. Fill through the check plug hole, takes 2 qts. Use Hy-Tran same as rear end & trans.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
