Posted by chadd on September 17, 2007 at 09:29:18 from (155.92.32.233):
In Reply to: stupid motor posted by smdv806 on September 16, 2007 at 19:01:59:
The advance mechanism on this tractor is mechanical and utilizes 2 weights that are attached to the breaker shaft (which slips over the distributor shaft) and precision springs. As the rpm of the shaft increases, the centrifugal force on the weights increases. This causes the spring to lengthen and the advance curve to change correspondingly. Problems with the advance system will cause backfiring or kick-back at start up or hard starting depending on where it is stuck. You need to remove the plate behind the points to be able to see the weights. More than likely a spring broke or the peg wore or broke. Also, you cannot replace the springs separately, so you have to buy two of them, and don't try getting ones from a junk yard, because those springs will be in just as bad of shape.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
