Hi, The plow will work best if the clevis is on the line of draft. To find this first locate the center of load on the plow, this is 1/4 the width of one bottom to the right of the center of the plow and just slightly above the joint between the plowlay and the moldboard. Place the tractor in front of the plow in its proper position, run a string from that point on the plow forward to the point on the tractor where the swinging drawbar would be attached under the belly. Put the clevis on that line and then adjust the plow hitch left or right so the furrow wheel is in correct alignment with the tractor tire. The vertical line of draft is best adjusted with the plow in the ground and the tractor in the furrow. Again find the center of load on the plow, run the string to the clevis on the tractor, adjust the plow hitch up or down to follow that line as close as possible. If you get these adjustments right the plow will pull staight and level, and the tractor will be easy to steer.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
