What you need to watch to avoid burning valves in those IH gas engines is the ash content of the oil. You need to be using an oil with an ash content of 1/2 percent or less.
The problem with the exhaust valves comes from the valve stems getting a layer of carbon buildup on them. This is not a problem as long as the load is kept constant on the engine but when you go to pull it hard the valves will get hotter and the stems expand. The carbon buildup then causing the valve to stick as little. When the valve sticks open under heavy load the combustion gasses leaking past the seat will cut them almost like a cutting torch. The low ash oil will not entirely eliminate the problem but it does greatly reduce it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
