Posted by Wardner on September 23, 2007 at 18:18:47 from (4.154.242.202):
In Reply to: farmall 460 diff lock posted by bm3501466 on September 23, 2007 at 17:28:17:
If you can lock one of the side bevel gears to the inside of the differential cage, that will work. If you had four spring loaded pins riding on a yoke or collar, the collar could be moved laterally to force the pins into the bevel gear. The bevel gear is splined to the bull pinion shaft. It would have to be drilled as well as the differential cage half. On a 560, you could use the blocked off shifter opening for the linkage outlet. I'm surprised someone hasn't already done the engineering and production.
Another solution would be the bull gears themselves. Fasten a large male spline to both gears and let a female spline rest on one and slide over to the other. Internal and external gears would work as well. Lots of torque back there so it has to be beefy.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
