Posted by chadd on September 25, 2007 at 14:17:47 from (155.92.33.252):
In Reply to: Tranny oil level plug posted by JohnG(TX) on September 25, 2007 at 13:44:37:
Part of the consideration is efficiency, part of it is cost. Gear lubrication is for the most part accomplished by the oil climbing up the gears as they rotate. In this manner, the oil gets thrown throughout the housing and into channels to carry it to other bearings, gears, and moving parts. If the transmission is filled to the brim, you have a significant friction loss on every submerged rotating surface, instead of just on the fraction of teeth submerged on the lowest ones. All of the spinning gears, bearings, and shafts churning and circulating the oil would add up to a lot of resistance, thereby greatly reducing the efficiency of the gearbox, especially when you start talking about 90W-140 gear lube. Also, it would be pretty darn expensive to fill the entire rear end case with fluid on one of these tractors, as there is a lot of space in there. Temperature is also a factor, as the fluid will expand.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
