Surging RPM on 706
Posted by KBrochman on September 25, 2007 at 18:25:53 from (206.8.88.78):
Hello,
I have a 706 gas w/ a 263 engine. It runs great,
but when I put a load on the engine the RPM drops a little and the govenor seems to over compensate and the engine RPM surges. Pulling out the choke helps. So I tried richening the main jet, that helped a little but, it would foul plugs. The engine has new points, plugs, cap, rotor, wires, and rebuilt carb. The fuel supply to the carb is good, the timing is set at ten BTDC and the advance works good. I adjusted all the carb and govenor linkage as per the IT manual plus replaced the springs. I disassembled the govenor and that is in good shape and I tried to adjusting the buffer screw, but none of this helped very much. I by passed the resistor by the coil, this seemed to help but not fully fix the problem. I wonder if I need more voltage, it has 13 volts at the battery at high idle. I'm thinking about putting and altenator on it. I got the tractor this way and have no history on it. Im stuck, any help would be greatly appreciated. Thank You!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
