Posted by ScottyHOMEy on September 30, 2007 at 19:16:34 from (71.241.214.74):
In Reply to: Re: mc cormick c posted by Damp;Dservice on September 30, 2007 at 18:43:48:
If there's no water pump, it couldn't hurt to pull the elbow on top and make sure nobody tried to put a thermostat in there that might be stickkng on you.
Also lube your mag through the forward oil cap. If the impulse coupler in the mag is sticking, it could screw up your spark timing and make her run hot. Drop some light oil (like 3-in-1) in there and let it sit and dump some more in after you next start it up. Worst case (not all THAT bad) would be the owner's manual procedure for pulling the mag, flushing the impulse coupler with kerosene and resetting and retiming the mag, if that turns out to be the problem.
If that coupler has just got dirty or dry and stuck, it might very well be your problem
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
