terryjd said: (quoted from post at 21:34:45 09/30/07)....
Seems to be a lot of Gen, VR questions lately, wonder if that means winter is coming? lol.
In a word: YES!
Sounds like the old ammeter was wired up backward. Recommend doing this:
1 - Install/connect the new ammeter.
2 - With the engine off turn on the lights. If the ammeter indicates discharge do nothing. However if it indicates charge, reverse the connections at the ammeter.
3 - Run the engine. The ammeter now should show charge.
Also if you have a voltmeter, stick it across the battery with engine running and the ammeter indicating charge. If the voltmeter shows 6.5 volts or higher the battery is being charged. (Less than 6 volts means it's discharging....)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
