Posted by Pete in Holland, MI on October 03, 2007 at 13:42:24 from (198.36.89.7):
In Reply to: starting problem posted by Bill Pingel on October 02, 2007 at 19:27:43:
Did you replace all 3 cables? Clean he connections to the engine? Have seen some cables clamped to a battery box or piece of tin. The junction here may be o.k., but where the tin joins the engine may be the problem. Suggest your ground strap go right to a bolt that screws into the engine block or transmission housing. Might take a wire directly from the battery to the motor starter to see if the starter switch itself is at fault.
Was told several years back that the electrical system on a tractor should be completely replaced every 15-20 years. That'll prevent a lot of little problems in the up and coming years.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
