Re: Hydraulic Help Please
Posted by K.B.-826 on October 04, 2007 at 16:39:17 from (66.188.196.198):
In Reply to: Re: Hydraulic Help Please posted by Janicholson on October 04, 2007 at 12:44:41:
Jim, that sounds like a good idea. I've had to do the same thing on a few skidloaders. Brian might not even have to go through the trouble of making a special cap for the reservior, mabey he can just stick a blow gun in there and hold a rag around the blow gun. I would do this with the engine off and the bleed screw loose like you say, if that didn't work I'd take the pump inlet line loose and pressurize the reservior until fluid starts flowing. Once fluid gets to the pump, the pump should pick up and go. On my little Farmall 240, which has similar hydraulics to a 400/450, the bleed screw is stuck. One time it lost prime after I did some work on the pump, so I cracked the pump outlet line loose with the engine running. Made a small mess but it worked.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
