Posted by Nat 2 on October 10, 2007 at 08:01:49 from (64.80.108.53):
In Reply to: 2 way hydraulics posted by Dalton S. on October 09, 2007 at 20:27:04:
Let's see if you really have 2-way hydraulics, first. Assuming you have belly pump hydraulics.
To have 2-way on your M, you must have a separate 2-way valve. The lever on the side of the tractor's belly is NOT 2-way.
There are the "christmas tree" valves from IH that were optional on Ms. The valve mounts under the gas tank, on the fill pipe for the belly pump reservoir. A long rod runs up to the operator. You lock back the belly lever, and use the lever to the christmas tree valve to operate the cylinder.
There are also aftermarket "spool" valves. These could be mounted anywhere, but usually somewhere near the operator. They look like the valve on top of a log splitter. Again, you lock the belly lever back and use the spool valve to control the cylinder.
In either case, you run a hose from the right-hand belly hydraulic port to the IN port on the valve.
On christmas tree valves, the OUT is already connected to the fill pipe on the belly reservoir. On a spool valve, you need to run a hose from the OUT to the fill pipe on the reservoir. Either way, you need to plug the vent in the cap, or replace the cap with a regualar pipe cap to keep the fluid from spraying out.
Run lines from the two work ports on either type of valve to quick connects at the rear of the tractor.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
