If it moves at all, it can be pretty simply doctored up by using penetrating lube on it (auto trans fluid is good) then working it in out 1/8" and around and around till it gets loose. Flush the casting and rod with lube till the dripping comes clean on the other side, leaving rust in the casting will wear it out radically. If it is stuck, I would put the crank on the snout with a 75# weight on the handle pulling down. Then I would heat the shaft where it enters the bolster (not red hot, but dang hot, then let it cool) do this for three or four times, then let it cool till cold. Tapping on the end and continuing to pull, is about the only way. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
