If system has all the right parts and you are sure pump is good the problem is most likly in regulator and safety valve or a suction leak. Suction leaks can be were the steering and valve support post bolts to reservoir with 4 bolts, gasket there, or at each end of suction pressure pipes to pump,O rings. If suction leaks on pump end oil will usualy leak though with tractor parked. If you get into regulator valve check for stuck pistons, bad springs or ball and seat not sealing. Also check screen and orifice for pluging while apart. Before doing any of that maybe we can determan if you have correct parts. The control valve nearest support post,does it have 2 hydraulic ports to front of tractor(they should have pipe plugs) or 1 port ? Does your regulator block have any ports in the bottom pluged or otherwise? Its posiable also that power steering and non power steering parts are mixed and a port left pluged off. Also make sure oil is getting to suction side of pump.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
