You are correct, you add fluid thru the cover right ahead of the battery box that has 3 bolts. Ahead of the clutch pedal, about half way down on the case there is a small pipe plug, remove that plug and fill till fluid appears (13-15 gal). That is the proper level. The hydaulics have a separate reservoir that needs to be serviced separately. Under the gas tank there is a tank with a drain plug ahead of the brake petals, above the rear end housing. Remove to drain. Right above the plug there are 4 bolts in about a 2" square that need to be removed to allow you to pull the filter out. If the filter is ok it can be washed out and replaced, however many times they are collapsed from operating dirty. They are availabe at your Case-IH dealer (pricey). After replacing, you refill thru plug above the filter, It has a dipstick on it and holds a couple gallon +/-. Good luck!!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
