Start at the fuel tank and check for flow. It must flow fuel like flowing through a sweetheart straw. If less, it is plugged up. There is a strainer in the carb intake fitting as well as other places. If the lines are OK, then pull off the float bowl and (with a pan under it) gently hold up the float and turn on the fuel. Lowering the float should produce drastic flow, if not, the inlet is plugged up. Good luck. As pointed out by Bob, the coil could be an issue. If it restarts immediatly but dies I go for fuel first. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
